you have the other one, more like a chinese finger cuff. once you have enough slack in the cable, you will need to push one of the two cable towards the middle of the clip. you may have to use a screw driver, or punch and a hammer to move the cable end to the middle. or just cut the clip and buy a new one.So once the adjuster nut is loosing and the cables are slack will the cable just pull out of the metal clip
If it's that style you may need to pry up the little fingersMay look like the slim one on this shot
But works the same way slack up on the rear adjuster and it should push forward and out.
