I take it the engine is out of the car? In the past I cleaned my engines myself. I found it to be a tedious PIA, so now I pay the local machine shop the $50.00-75.00 its costs to hot tank the block, heads, timing cover, oil pan, and intake. Its a lot less mess as well. If you are set on doing it at home, this is how I used to do it. For the heads I scrapped all the big stuff off with a putty knife, and then used a 5 gallon bucket and put some mineral spirits and the head in there. I then used a brush and scrubbed them clean. After I got all the crap off, I sprayed them down with brake clean to get any oily residue off of them. For the block, I scraped all the chunks off with a putty knife. I then soak it down with easy off oven cleaner and let it sit for about 10-15 min and them scrubbed the block with a brush. I repeated the process until I got it all off, then sprayed with brake clean. Easy off will work well on iron heads too, I don recommended using it on aluminum heads.
