mikester
This is an easy fix. Find a G body at the junk yard that still has the AC in it. Get the plastic lines fron the INSIDE ! Theyre usually in pretty good shape. Cut them right at the firewall behind the glovebox. You have to check the ends that go on the actuators. Theres two sizes. Ones larger than the other. I did this. I know it for a fact. Lines the same size, the ends are different.That's what I figured. I have seen them on newer 90's cars. I'll find some. Thx.
After you get some decent soft line cut the dried out brittle ones off your car about 3-4" out from the firewall on the outside. You need to go to a lawnmower repair shop and get gas line for a chain saw or blower. You'll need to match the inside diameter of the gas line to the outside of the vac line. Slip the two ends in and put a little dab of super glue on the splices. Done. I had to do it inside and out on the wagon and it works fine.
