I'm reading 3 different scenarios when it comes to initial and total timing on a SBC...
Scenario 1, Factory Settings: Initial is 6° BTDC @600 RPM in Drive, but doesn't specify the total timing...I'm guessing 34-36° total with the initial being 6°.
Scenario 2: Says here, with the vacuum advance hose disconnected and plugged at the hose, to:
1. Set the initial timing to 4° BTDC.
2. Connect the vacuum advance hose back to the distributor vacuum advance canister...timing reading should advance 18° plus or minus two.
3. Raise the RPM to 3000 and the timing reading should show 32° total timing, and if not, advance or retard the distributor to achieve 32° total timing.
To establish the correct advance curve, the vacuum advance and mechanical advance in the distributor must work properly with no binding. When a small-block Chevy is started, the spark is retarded to 4 degrees BTDC. As soon as the engine starts and a vacuum is produced, the vacuum advance...
itstillruns.com
Scenario 3: 12-18° BTDC initial timing and 34-36° total timing...
Which one is correct ? I'm willing to bet my cam, lifters, rockers, and H.O. heads are stock.
Should I start with the factory settings of 6° BTDC @ 600 idle rpm and total it at 34° ?
The other options outside of the factory settings didn't specify what the RPM needs to be when setting the initial timing...does it even matter or should it be higher when setting the timing at higher degrees BTDC?
