i saw a post in the monte section for the difference on euro models.
i think some of you could find it interest for the regal
Tailight with yellow turnsignal, yellow sidemarker in the back (red wasnt allowed at the side, but laws changed if they are in the same housing as the backlight its ok), 2 stoplight instead of parking and parking/Stop/turn
and these swissmodel got 2 reflectors at the back
if you break and hazard is on, the turnsignal arent changing from blinking to stay on
sidemarker in the front where wired to a turnsignal. it have to be that all turnsignals are blinking in the same frequency and not inverse. the 4 yellow parklight (two in the turnlights) at the front are cutted because it isnt allowed to have yellow light to the front. sealed beams are removed and replaced with euro headlight (hella or bosch with lamps and integrated white parklights in the outer lights
the mirrors are different (they are the standard mirrors for GM euro models) and can be moved
AND no Cat, CCC and ECU at these 84 with 305 sbc
tires was 205/75x14 in size with a 2:27 rear
the exhaust is stock 2 cause there is (was) a problem with the tailpipe exit to the right
http://www.getsome.de/taillight.jpg
http://www.getsome.de/front.jpg
