ever boxed your rear trailering arms?
79elcaminoo
minnesota
i was just woundering if any one has done this? do you think its a good idea? shoul di do both upper and lowers or just the lowers?
we box them on our circle track car and it stiffens up the rear end. I'm going to box a set for mine when I get a chance. I just changed my rear end so I reaaly shuda had a set ready for then but we start testing in 10 days and the race car comes first..
it'll cost you a few $$$ for the plating to box them instead of big $$$$$ buying them. When you box them make sure you leave enough clearance for the ends so they don't bind and don't forget to weld in the spacers for the rear sway bar before you box them.
With a lil shopping and the price that you can buy better stronger lighter aftermarket arms with poly bushing (not the best thing but better than mushy worn rubber thats in your stockers) with grease fittings. I would buy aftermarket. Also I bought the Edelbrock double adjustable uppers so they can be adjusted on the car. This is the ideal way to reset the pinion angle so as to plant the tires and lift the front of the car for best traction. Instead of lifting the rear of the car unloading the tires and spining. I think GM set them up this way to keep abusers from breaking drivetrain and suspension parts.
Hey I recognize that link :lol:
I am not going to repeat what's there, just read it.
Unless you are stepping up to chromoly tubular lowers, even then it's only 2#, aftermarket will weigh more.
Hotckis lowers weigh a good 5# more per pair then boxed stockers.
Metco uppers 4# more then stockers.
Boxing the lowers is one of the best bang per buck thing you can do to your rear suspension.
dogsh!t.... That's a myth that the pinion angle affects traction...the upper and lower rear control arms and combined with weight distribution, spring rates, and shock valving is what affects traction.
pontiacgp is right, but it can effect your E.T.
You should see what I do with end link and shock bushings 8) .
