ever heard the squeek?
arent the brakes vaccuum assisted? because my brakes are adjusted right and have plenty of meat on them. and i bled the hell out of them and they still suck. could they have somethin to do with eachother?
That could be. Check all the vacume lines that are connected to the brakes. If still nothing. Maybe it's the brake booster. Get a buddy to shut the car down while you're listening under the hood. Listen to the brake booster, if you can hear that the sound is coming from there, that could be the problem.
How does the pedal feel?
figures that once i want it to squeek it wont. it doesnt do it all the time. thats the weird thing. but my breaks are always crappy. i defenitly cant stop fast if i need to. the pedal has some play in it and it feels like it loses pressure at a stop light very little though, it never goes all the way to the floor. and i bled the hell out of them when i adjusted them.
Sounds like your master cylinder is internally leaking. I doubt that would be causing the noise though.
tumtum said:
how would i look into that further?
I really have no idea if there is a way to check if it is internally leaking. It also could be leaking on the outside, check for some fluid running down the brake booster from the master cylinder.
