Exhaust manifold bolts
Ridgeline
131
Can someone out there tell me what size bolts I need to put a set of stock exhaust manifolds back on my 403 olds? It has headers. Will the header bolts work? Thanks in advance.
should be 3/8" course thread
Well, I have never heard of a grade 7 bolt but I would just use Grade 8 standard. Your local NAPA store should have a bolt bin yopu can get these from. Although, running exhaust manifolds gives you the option to run studs so I would get atleast a couple for each side to make things easier.
Grade 7
133,000 psi
Med. Carbon
Alloy Steel
just a bit softer then a grade 8 easier to drill out if needed
