why not get the weld on ones bigger than your exhaust and drill and tap them to make them screw on
thats using your noggin!...best idea yet...1979ratrod said:why not get the weld on ones bigger than your exhaust and drill and tap them to make them screw on
I know this might sound silly but how do I go about doing this? Never done this or seen this done before.1979ratrod said:why not get the weld on ones bigger than your exhaust and drill and tap them to make them screw on
Where can I get one that is 18" long and fits on 2.5" pipes that doesn't cost an arm and a leg?tc1959 said:Alot of them have built in clamps now.
head down to sears and pick up a tap set and then find the set of tips you want but dont get them too much bigger. mark maybe like 3 or 4 spots to put set screws in evenly spaced and drill holes a tiny bit smaller than the tap your going to use. start threading in the tap and back it out and keep going a little further in each time till go go all the way through then find some screws or bolts to thread in and your done!UOFLcards said:I know this might sound silly but how do I go about doing this? Never done this or seen this done before.1979ratrod said:why not get the weld on ones bigger than your exhaust and drill and tap them to make them screw on
