I have owned my '81 Grand Prix since new and I thought I would give the engine bay a facelift. Here are a few pictures.
I originally was going to do just the valve covers, but once I got those off and saw how rusty the block was I couldn't stop there.
First I removed everything I could and I ended up with this.
Then I primed it.
Painted it GM blue.
And finally reassembled it
I had all the brackets and pulleys powdercoated, disassembled the alternator, distributor and air pump and painted them with Alumablast from Eastwood. I painted the P/S pump and and A/C compressor and bought a new decal for the compressor.
I think the hardest part was masking the area off. I didn't want to get overspray on the firewall or the frame. I went into too much detail also. Once I had the block painted, I looked at the exhaust manifolds and had to do something with them. I bought some 1200 degree paint from Eastwood and hand painted, with a small paintbrush, the tops of the manifolds - at least were you could see. They turned out real nice but once I assembled the engine back together, you can't even see them.
Then I primed it.
Painted it GM blue.
