Were they off a early 1970s A-body Olds? They had a bigger backspacing it seems.
http://www.442.com/oldsfaq/ofwhl.htm#Wheels
* 1966-69 SS Is: 14x6, all chrome, with 4.5" backspacing.
* 1968 - 69 SS IIs and IIIs: 14x6, bolt on cap, narrow trim rings, with 4.5" backspacing. NOTES:
* 1970 - 72 SS Is: 1971 was the only year for the all chrome 14x7 SS I. All other 14x7s used trim ring with 4.5" backspacing.
* 1970 - 72 SS IIS and IIIs: 14x7, bolt on cap, with 4.5" backspacing. NOTES:
* 1973 - 74 SS IIs and IIIs: bolt on cap, 14x7, 15x7, with 4.5" backspacing. NOTES: 15x7 a bit hard to find.
* 1975 - 1977 SS IIs and IIIs: snap on cap, 15x7, with 4.5" backspacing. NOTES:
* 1978 - 1988 SS IIs and IIIs: snap on cap 14x5, with 3.5" backspacing. NOTES: The lesser backspacing is for clearing the outer tie rod ends on the later (1978-88) A and G bodies. 15x7 SS IIs with 4.5" backspacing fit the later A & G cars since the greater diameter places the rim edge far enough away from the tie rod end.
* Generally speaking, in the 1980's, the SS III was the chrome wheel, while SS II's were painted lower body color.
* In the 1970's, the SS II was argent, with the SS III being painted lower body color.
* All 14" wheels can share the same trim ring. All 15" wheels can share the same trim ring.
* All SS wheels, regardless of application year, will clear the 1968 - 72 A-body cars.
