Update:
This weekend:
Saturday:
Replaced all vacuum hoses that were bad or marginal.
Replaced the EFV valve cause it tested bad.
Tried to replace the MAP sensor, but the one sold to me did not have the right plug on the end. Returned it.
Was going to replace the Catalytic converter, however, it was wrong too (was supposed to be a bolt in replacement. It did not have the square front flange, and the rear flange bolt holes would not have lined up.
Replaced the filter on the Evap canister.
6ish hours of work.
Sunday:
Swapped to a 195 thermostat. I've since swapped back to my 160 after the test as the motor feels like a total dog when warmed up.
Took my free emissions retest.
Results:
25/25 Test:
HC: 92 (144 Allowed)
CO%: 0.06 (0.92 Allowed)
NOx ppm: 1215 (1014 Allowed) Failed
RPM: 1317 (2500 max) How do they determine this?
CO+CO2 %: 11.9 (6.0 Minimal)
50/15 Test: Here things get wierd
HC: 302 (148 Allowed) Failed
CO%: 2.83 (0.83 Allowed) Failed
NOx ppm: 1142 (1119 Allowed) Barely failed.
RPM: 1450 (2500 max) How do they determine this?
CO+CO2 %: 15.3 (6.0 Minimal)
Okay, things were slightly better overall on the first test and especially NOx. Second test though just makes me go what the ....?
Got home, stuck the dwell meter on it, m/c has a dwell averaging around 12 at idle? Why is the computer calling for enrichment?
Replaced thermostat since I like my car to pickup speed when I floor it.
Seafoamed the engine by adding it to the carb (it ended up killing though), didn't see the huge puffs of smoke most people get.
Idle is a lot smoother then it used to be, although has some light roughness to it. Part throttle power is up a good bit and it will run on regular again now with no valve noise.
I guess my next goals are to get a new catalytic converter, replace the water temp sensor (It wouldn't come out easy when I was trying to turn it them morning, I'm a bit afraid of stripping the aluminum.
Put in the set of AC Delco plugs I bought.
The listed the test weight of the car at 3750, but there is not a full scale for all tires on the floor. How are they coming up with this weight? I also had a half a tank a gas and the guy testing was probably around 200. Where did my car pick up 500 extra lbs?
Plug wires, cap, and rotor where replaced about 2 weeks before my initial test. I changed the fuel filter while the carb was off while cleaning the EGR valve. I replaced the PCV and replaced the crankcase ventilation filter when I did the plug wires, cap, and rotors.
