Here's more pics as well, some before and after.
http://s962.photobucket.com/home/carlp91
Here's a quick reference list of everything done.
-Body bushings have been replaced
-New brakes, Disc-front and drum-rear
-New KYB Shocks front and rear
-New BF Goodrich Tires
-Painted Rally wheels with Trim
-New Front end has been rebuilt new with Moog parts.
-New Front has new 2 inch drop spindles (proper way to lower the front end)
-New Rear 2 inch drop springs
-New Performance Upper and lower trailing arms.
-New Windshield with antenna build in, New power locks and power windows
-Small Block 350, bored over to a 355
-New Alum Radiator
-Eldelbrock top end
-Newer coated headers
-New full dual exhaust with balance and 44 series Flow-masters (Sounds BAD!!)
-Street cam
-Ported heads
-New Electronic Holly Fuel Pump relocated to the rear.
-Battery and fuel pump have been relocated to the rear
-New Turbo 350 transmission built to handle over 750 hp, shift kit
-New GM Posi unit with 3:73 gears
-Altered driveshaft
-B&M Floor shifter
-New none power steering pump
-New converted to Electric Fans
-Removed Heat and AC, nice clean block off plate for the firewall.
-The body was JUST painted, 4 lower Rear sheet metal panels were replaced.
-New 2 inch Cowl Hood, FiberGlass Bumpers, Front Lower Air deflector
-Pick-up bed has some wear
-Interior has custom tweed Fiero buckets seats, dash, gauges, new carpet, headliner, Door panels and gauges are next to be installed to be totally complete.
