Yes, this is correct.... Once I figure this out I'll repost... Thanks guysclean8485 said:The '78-'88 GM A/G body cars (and pickups, in the case of the El Camino and Diablo), were factory equipped with manual transmissions from 1978 to 1981. 1981 was also the last year for the wiper switch on the dash. In 1982, GM went with the wiper switch on the turn signal lever in 1982, but by then, there was no manual trans option available. The factory manual trans vehicles have a key release lever built into them, as mentioned above, so that the key could be turned back to the lock position when the vehicle is shut off, so that you can remove the key.
Geo's66, I'm assuming that you're looking for a tilt column that looks correct for your manual trans '78 Monte. If I'm correct, the way I see it, you have 2 options-you can find a correct tlit manual column for your car, or you can build something that looks correct and works like an original tilt/manual column.
Please keep us updated with what you decide to do. Good luck.
