Firestone Town and Country Snow Tires
6,103
13,175
My1995 F150 I recently bought for $300 came with 4 unused tires, 2 of which are Firestone Town and Country's with a whitewall on one side. I don't know how old these tires are, but from the small amount of research I've done, they are likely older than me. It seems Firestone hasn't made them in quite some time. However they aren't dry rotted in the least and the rubber is still super soft. I've been driving on them for a few weeks now and I've got to say, they are fantastic in the snow. They are super soft, have really knobby aggressive tread, and are very skinny which is great for snow. They almost look like tractor tires. If anyone knows where I can buy these tires, either new or used, let me know, as they are some of the best tires I've ever driven on. The size is 235/75/15 but I'll even buy other sizes if I can find them.
A little tire info
Tire Tech
Determining the Age of a Tire
(Lea en español)
When it comes to determining the age of a tire, it is easy to identify when a tire was manufactured by reading its Tire Identification Number (often referred to as the tire's serial number). Unlike vehicle identification numbers (VINs) and the serial numbers used on many other consumer goods (which identify one specific item), Tire Identification Numbers are really batch codes that identify the week and year the tire was produced.
The U.S. Department of Transportation (DOT) National Highway Traffic Safety Administration (NHTSA) requires that Tire Identification Numbers be a combination of the letters DOT, followed by ten, eleven or twelve letters and/or numbers that identify the manufacturing location, tire size and manufacturer's code, along with the week and year the tire was manufactured.
"When it comes to determining the age of a tire, it is easy to identify when a tire was manufactured by reading its Tire Identification Number (often referred to as the tire's serial number)."
Tires Manufactured Since 2000
Since 2000, the week and year the tire was produced has been provided by the last four digits of the Tire Identification Number with the 2 digits being used to identify the week immediately preceding the 2 digits used to identify the year.
Example of a tire manufactured since 2000 with the current Tire Identification Number format:
In the example above:
DOT U2LL LMLR 5107
DOT U2LL LMLR 5107
Manufactured during the 51st week of the year
DOT U2LL LMLR 5107 Manufactured during 2007
While the entire Tire Identification Number is required to be branded onto one sidewall of every tire, current regulations also require that DOT and the first digits of the Tire Identification Number must also be branded onto the opposite sidewall. Therefore, it is possible to see a Tire Identification Number that appears incomplete and requires looking at the tire's other sidewall to find the entire Tire Identification Number
The use of a partial Tire Identification Number on the one sidewall (shown above) reduces the risk of injury to the mold technician that would have to install the weekly date code on the top sidewall portion of a hot tire mold.
Tires Manufactured Before 2000
The Tire Identification Number for tires produced prior to 2000 was based on the assumption that tires would not be in service for ten years. While they were required to provide the same information as today's tires, the week and year the tire was produced was contained in the last three digits. The 2 digits used to identify the week a tire was manufactured immediately preceded a single digit used to identify the year.
Example of a tire manufactured before 2000 with the earlier Tire Identification Number format:
DOT EJ8J DFM 408
DOT EJ8J DFM 408
Manufactured during the 40th week of the year
DOT EJ8J DFM 408 Manufactured during the 8th year of the decade
While the previous Tire Identification Number format identified that a tire was built in the 8th year of a decade, there was no universal identifier that confirmed which decade (tires produced in the 1990s may have a small triangle following the Tire Identification Number to identify the decade).
And finally, hold on to your sales receipt. Most tire manufacturer's warranties cover their tires for four years from the date of purchase or five years from the week the tires were manufactured. So if you purchase new tires that were manufactured exactly two years ago they will be covered for a total of six years (four years from the date of purchase) as long as you have your receipt. If you lose your receipt, your tires' warranty coverage will end five years from the week the tire was produced (resulting in the tire manufacturer's warranty coverage ending only three years from the date of purchase in this example).
With a metric # they have to be late 70's at least. I'm sure they're past their expiration date, its up to you if you'll drive on them.
Many of our cars have rubber from the 90's on them, no cracking, not dry, they are garage kept and this helps. A friend has tires that are 50 years old on his 51 dodge. Yet, I have had bubbles and issues with tires that are from this century.
Yeah, I've had a lot of issues with dry rot. I'm sure these tires are 'expired' but they were unused and still had stickers on them. They aren't hardened or dry rotted so I don't personally have an issue driving on them. If they were dry rotted, bubbled or hard, it'd be a different story.
I haven't seen those kind of tires since the 80's. I remember them from old catalogues and magazines that were around as a kid.
I seem to recall when I bought my Calais in 90(ish ) it had 2 of those on rims in the trunk for winter. I also seem to recall they would "skin" really easy if you put any heat into them ( tossing the outer belt and leaving the tire intact ) resulting in a lot of bent rear quarter panels. I never used the ones that came with the car. Likely something a Coker Tire would reproduce if you really wanted a new set.
Little digging turned up an ad from 1959
http://www.ebay.ca/itm/like/381840442412?lpid=116&chn=ps
Coker tire, super traxion
https://www.cokertire.com/tires/styles/military-and-truck.html
The tires on my cutlass are NOS from the last 20 years (don't remember the year). They had the stickers on them too. On the way home from cruisin weekend this year it developed a massive bubble in about 5 seconds @ about 80mph... scary. I have a spare and made it home, slapped on my one extra full size tire I had left, and the next time this happens, I'll be replacing the set.
Yet, on the same, my truck has bfg KM2's, a relatively new tire (<10 year old design, my tires are newer), and I have had 2 develop bubbles in the tread.
With tires, it just seems to be a crap shoot.
