Firewall / Frame Torque Boxes
If you are going to repair that I suggest you find a good donor car that you can use half the firewall and the floors, I also suggest you get a rotissary cause it is no fun welding on your back. Personally I would find another car and keep the front clip and quarter panels
I picked a better shell yesterday I just got it in my garage I’ll post some pictures in a little bit
Not perfect but a lot better than what I started with. The rust on the front floors is surface and they are still solid. The rear pans are tender and I will cut them out of the blue car. Surprisingly they are rust free considering the shape of the rest of the car. It needs a drivers rear body mount support. All the trunk metal is solid as well as the rear seat body mount support, and inner rockers are mint.
Reactions: paul.m and TURNA
Looks better than the first car you were showing. On mine, I got out to the garage today and started scraping rust and it's not as bad as I originally thought. Looks like the first layer of metal is shot but the underlayer is solid. Guess I'll cut the top layer of rust and just add a patch to make it as thick as original.
Reactions: DysonSS
That shouldn’t be to bad to patch. A little trimming and weld in a new piece. I think 14 gauge steel is what was used from the factory. Don’t quote me on that because I’m not 100% sure.
