hat sounds like a good idea but instead of splicing wires why not just replace from the bulkhead out ?
If you've ever priced all the wire in the same factory colors, it's quite pricey. I thought about putting the whole harness on the table laid out and replace them all.
Then I priced it out 👎 It's too much to do that for me.
Hutch
Hard to really tell, and might not help since my fuse block has been relocated. The EFI harness enters the firewall directly behind the intake, and any factory wiring exits into the engine bay at same spot. For the prop valve plug there is a hole in the floor with a grommet.View attachment 148448
if you look to the right of the steering shaft you'll see my loom.it's a bit cleaner.also i used the nylon over the plastic wire loom,it's a no brainer,no tape or ties.it wraps around itself.super clean working with/install.
View attachment 148454![]()
Summit Racing® Braided Wire Wraps SUM-890341
Find Summit Racing® Braided Wire Wraps SUM-890341 and get Free Shipping on Orders Over $99 at Summit Racing! Tuck your wires into Summit Racing® braided wire wraps and you and your ride will both be happy. The wires will be protected from abrasion and damage, and you'll enjoy the nice, neat...www.summitracing.com
Just a thought but what about running the wires that go to the passenger inside of the car behind the dash.
where did i put all that stuff??a lady never tells..I'm sorry i couldn't get back to you today with this i've run out of time.if you're still interested i'll get with ya tomorrow after work.let me ask you how much of the engine wiring is done?alt/compressor etc etc.So everything runs down behind the motor ? Where did you put the compressor, alternator and sender wiring ?
I just got back from buying some insulated cable clamps. I was going to use 5/8" loom out from the bulkhead with the larger tee but after messing with all the wires I think I can use 1/2" instead. Of course that's more flexible and uses smaller connectors which will probably look a lot better. I was trying to use the OEM clamps but the insulated ones are a lot smaller. I didn't like the way they looked at first but I pulled the rubber off one and painted it with silver cadmium. Put the rubber back on and it doesn't look that bad.
I'm heading back out there when I stop typing to see how I can make this look nicer. Maybe some pictures later in the day.
