So I did the first oil change on the new 496 2 days ago and had it running for about 10 minutes that night. Fast forward to today I start it up everything is normal but I have a HORRIBLE knocking noise. I immediately thought my brand new engine is junk. I noticed that the knock went away as I increased the rpm. Check the oil pressure and its normal. 40 psi at idle and with a blip of the throttle it hits 80 psi so that put my mind at ease.
I climb under it to check the torque converter bolts and as I put a wrench on one of the bolts the entire torque converter and flex plate rotates about 1/4" on the crank!!! I can literally wiggle the TC and flexplate by hand back and forth. So now I know I gotta pull the transmission back to re-tighten the bolts but my question is what would cause flex plate bolts to randomly loosen? It was fine one day then the next day it's knocking like crazy. They are 12pt ARP bolts torqued to ARP's specs with red lock-tite. The flex plate is an externally balanced Scat plate that came matched with my rotating assembly. Any ideas???
