I may have messed up i used the flexplate from my 4.4 for my 350, will it work? I'm also wonder what harmonic balancer ill need?
Thank you.
Thank you.
As long as the flexplate did not have cracks or damaged teeth on the ring gear, you should be fine. The 267 (4.4L) had the early 2-piece rear main seal crank shaft. 350s used 2pc (early) or 1pc rear main seal ('87+). All early-style 267, 305 and 350 engines are neutral-balance, so the flexplate is interchangeable. The good news? If it physically bolted up, you're good to go. The 1pc cranks and flexplates use a smaller bolt circle.
PS - you're happy that your car came with a 267. Its best features were the accessory brackets and the right fan shroud for a V8!
