Not sure if my linkage is bent or I have the incorrect shift lever on the end of my transmission. Pic 1
When I install the short end into the shift lever. I'm expecting the other end to swivel where the plastic ball is. Problem is my swivel end is swinging in a giant arc.
In pic 3. If blue dot is the shaft sticking out of transmission, the pivot point will be the blue line. Maybe I have it installed upside down.
The more I look into shifter linkages, the more styles, shapes and angles I'm finding. Like .......pic 4 and 5
This is for a Grand National with a floor shifter. This linkage runs to the column to operate the starter safety neutral, reverse lights and key out.
