Straight through muffler flow rates don't prove anything. Come on, man.
By your rationale, you would be stating that every single engine combination would run better through open headers or straight pipes, right? WRONG!!
I don't care one fig about blow through flow numbers. That is not what Flowmasters were designed for. They were designed to have the inner V-chamber create a pressure drop with a scavenging affect.
Engine dyno numbers matter and quarter mile times certainly matter. If you have a documented story or some other PROOF that someone took off his flowmaster, put on the same size inlet and outlet pipe, and then took another quarter mile run with results, I would love to see it.
What I saw was an article in Custom Rodder, probably around 1995. They featured a 1965 Buick Special that they were working on. They warmed over the little 300 small block V8 and added a 2004r
Grand National transmission to it. They were searching for performance from the exhaust next.
First, they ran a set of 2 1/2" duals with garden variety turbo mufflers after scrapping the stock single setup. Next, they ran high dollar high flow mufflers. Last, they ran a single 3" setup with a nice y-pipe that they made from 2 1/2" mandrel bent tubing and a flowmaster 2 into 1 transition piece. They used a single flowmaster and the single exhaust setup beat the others on the dyno.
So here is what I'm saying. Exhaust has to be tuned just like the rest of the engine. Don't be so hasty to throw Flowmaster out. If you don't like the sound, then that's fine. I do like it, and my last two 12.7x cars liked them, too.
Post your dyno results if you have actual testing to prove that Flowmaster is no good. A google search on flow is meaningless.
