Guy claims zero miles on a rebuild on both, built it for a 71 Skylark and now he's getting kicked out of his house, and is moving out of state and can't take it with him. And he wants to get a Buick engine for it anyway. I think I'll go take a look at it, pull a valve cover and see if I can borrow a scope to look down the bores and see if his claims seem true. Anyway, I know this has been answered a zillion times... But other than motor mounts, and modifying or removing the AC box, what needs to be done to put this in a 307 moldmobile powered car? IIRC the TH350 will bolt right up to the cross member in the car... And I need motor mounts (part number would be great I can get them right at work), and what else? Ideally probably heavier duty springs but I'll deal with that later. :lol:
The engine doesn't have a carb or distributor with it, could I temporarily get by with the the stock 86 307 Q-jet and dizzy? Obviously I would upgrade, but just as a temporary solution for a couple weeks. Will the drive shaft bolt up? Going from a TH200 to the TH350? I don't have a lot of money is the problem, but it's become kind of urgent that I get a new motor in the car... I blew the intake gasket on the 307 and it inhaled a lot of coolant, and when I saw the crud and smelled the burned oil and antifreeze inside the motor... It's pretty much toast. I'm sure it will still run and I should have it put back together in a day or two but this engine's days are numbered. The inspection is up in a month or two, so I think I'll get it inspected then do the swap... This way it'll pass, and I can get it by emissions next year by keeping it under 5,000 miles.
I think I can get the pair for under 1,000 bucks... Which is about all the money I have left I haven't been able to save anything for months it'll tap out my account but I think it's better than buying some piece of crap replacement junker and have it break down in a couple weeks anyway. Probably shouldn't have bought that Firebird... But oh well it'll be worth it. I might have to see if I've got any matured bonds.
