How thick a layer should the dry pack be layed? The old floor is pretty high already with the bathroom doors just barely not scraping the old floor tiles.
Quarter of an inch minimum we have went as deep as four inches beforeHow thick a layer should the dry pack be layed? The old floor is pretty high already with the bathroom doors just barely not scraping the old floor tiles.
As long as the layer is solid and stable one is good. If it moves or flexes squeaks another layer is a good ideaI have another question. Does the drypack method still require two layers of plywood underneath?
This is why I work with new construction. Much easier than remodeling and fixing other peoples mistakes….So I have most of the first layer of plywood which was really thin removed along with all the tar paper and roof shingles. The second layer of plywood has old mastic residue so it was likely tiled at one time. It seems the roofing shingles were used as shims. The second layer is made up of mismatching plywood. Half of the room is OSB while the other half by the tub is non OSB. Really haphazard construction.
Did a little poking in a rotten spot of the second subfloor by the corner of the tub on ths non OSB side. So it looks like under this second layer of plywood is another layer of linoleum. Looks like they just kept putting new layers on top of old ones for decades. Impossible to know if its lazy POs, lazy contractors, or a mix of both.
Or going through the joy of finding a mummified turd (or body of something or someone) in places there shouldn't be one. 😳This is why I work with new construction. Much easier than remodeling and fixing other peoples mistakes….
