I just have a couple of questions about bracing the frame.
1) I checked out an F41 Suspension Package auction on ebay, and there was a bar for the front of the frame that bolts on to each side of the frame where the two bars come off from under the motor cross member end. Is that standard equip. on a GP, or is it strictly F41. just thinking because the guy on ebay said it was for the GP as it had the heavier fender braces. Also, the same question with the radiator braces, (the ones that cross in front of the radiator) just wanting to know because if it is standars GP equip. I could get them cheap fropm the junkyard.
2) I was looking at the rear seat braces, and thought it wouldn't be too hard to make those myself. if i were to make them myself, which type of metal should i use? my dad has access to scrap metal where he works, so he could probably get anything. we have some aluminum at home here, but it is only like 3/4" wide and 1/8" thick. what do you guys think as far as thickness and stuff? any help is appreciated.
