frames on el camino
cutty
207
near london ontario canada
my buddies el camino needs a new frame as his is rotted in odd spots,but what he is wondering is what frames will fit it,he plans on pulling the body off soon,and would like to have a frame to put under it when he does, any help would be great
Wagon frames will not fit, they are the same wheelbase as the coupes and sedans.
El Camino's are in a class of their own, so only a frame from another El Camino will work.
There is also seller on eBay that has clean rear frame horns up all the time for like $150...
The frame for an El Camino is essentially the same as every other g-body, with the exception that the wheelbase is 9 inches longer.
The rear rails on the El Camino are also different, as they have a slight recess on the driver side to accomodate for the side fuel filler neck.
Wagon's also have this slight recess for the fuel filler.
The wheelbase for ALL coupes, sedans, and wagons is 108.1 inches.
The wheelbase for El Camino's and Caballero's is 117 inches.
