I have a 84 cutlass that started out as a V-6 car. I removed the V-6 to make room for a ZZ4 turn key. And since I have had problems with my fuel tank venting. I know I created the issue but now uncertain how to correct it. My fuel tank is equipped with a 3/8'' and 1/4'' line assuming the 1/4'' is a vent line. I did not reinstall the vapor canister with the swap so I just capped off the vent fuel line. My engine is equipped with a mechanical pump with a supply port and delivery but no return port. Do I put the canister back in? Or install a fuel pump with a return line port, or a fuel pressure regulator with a return port? I have been pondering this issue since I started my frame off restoration last fall. I also need to order fuel lines but uncertain what lines to order. Return line or another vent line. Thanks in advance for any advice or suggestions.
