I asked this question in the general technical forum and got it almost answered thanks to the guys there . It was suggested there that I ask here so Ill rephrase and ask you racers. SOME BACKGROUND INFO :I have an 85 Monte SS ,350, 30 over shot peened and race prepped, scat 4340 crank, arps studs, high vol oil pump w/ high vol shaft and rod, speed pro pistons/ flat top 9:1 comp, ported and polished 882 heads, roller rockers, new springs locks and retainers, keith black push rods, double roller timing chain, comp cams nitrous/sc cam, .507 int lift .525 exh lift .284 dur int ans .305 dur exh, 113 lob sep, solid lifters, B & M 144 blower totaly rebuilt, Demon 750 cfm, long tube headers, holly performer mech fuel pump, TH350 fully built, shift kit, 3500 stall, 9" converter, eaton posi 4:11 gears. I normally only use the car to drive Grandma to church on Sunday but weve been running a little late lately so I figuered I needed to upgrade, LOL only kidding OK heres the question. I removed the stock gas tank in prep for redoing the rear suspension, (back half w/ 4 link or hotchkins style adjustabls, not sure yet , but thats another question) Im in the process of installing a foam filled racing fuel cell but see that the original tank had 3 fuel lines going to it. 1, the main fuel line and from what I learnd the othe 2 being a return line and a vent line that went to a carbon canister. My current fuel setup does not have a return so Im almost positive from what people have told me that a return is not nessessary , any thoughts on that? Also what do I do about venting of the new tank?
