Fuel pump for a 383...
moose
188
16
ICT, KS
...want a mechanical type w/out a regulator. Been told that something like this will be sufficient... Holley 80gph
This is my daily driver that I'd like to have a little fun with on the weekends. Any thoughts, opinions, suggestions from experience?
Also, I've read that a 1970-71 Camaro/Corvette stock replacement fuel pump (from O'reily's and the like) have a free flow rate of 90gph. Any truth to this? If so I'm thinking of slapping on one of those for half the price of the Holley.
I don't think any factory mechanical pump put out that kind of GPH -
The below are the specs for the mechanical pump for a 70 Corvette with a 350 and Holley carb(although the quadrajet specs appear to be the same).
Part Number: 40709
Weight: 1.4 lbs
Warranty: 1 YR
Application: With Holley carburetor
Gaskets Included: Yes
Inlet Attachment: Tube
Inlet Count: 1
Inlet Size (In): 3/8
Installation Hardware Included: Yes
Maximum Free Flow Rate (gph): 40
Maximum Pressure Range (psi): 9
Minimum Free Flow Rate (gph): 40
Minimum Pressure Range (psi): 7.5
OEM Part Number: 6440709
Outlet Attachment: Threaded
Outlet Count: 1
Outlet Size: 5/8-18 UNF-2B I.F.
Package Contents: Mechanical Fuel Pump
buy a summit racing brand #sum-25000-1. It's the same exact pump as that holley. Summit doesn't make parts they just rebox other manufacturers and put there name on it. Alittle cheaper then holley but if you look at the summit pump it has the holley number stamped in it.
Thanks man, I already got the Holley however. This is the second time this week someone has pointed out that I'm overpaying for a name. I just want to make sure that I'm not robbing my engine of power and have a habit of going all out to make sure. :roll: Oh well, you live and learn. And I'm learning to do more research before I whip out my wallet, and that Jeg's kinda sucks. A tech rep sold me some headers that didn't even come close to fitting, I bought the Holley with the credit they gave me so at least it didn't seem like I was forking out extra cash at the time.
