fuel pump on sbc going into a 87 cutlass with 307 olds QUICK
bryguy39
Apr 25, 2007
89
6
the cutlass has 2 lines coming from the tank, here is my question. Do i need to get a pump for my Sbc that was 2 nipples and the square deal on it that goes up to the carb? Please let me know asap so i can go get one if so.thanks,Bryan
Technically, you don't HAVE to. Of the two fuel lines, the large one is the fuel supply line and the small one is a return. You should have one more line on the other frame rail coming from the tank that is your vent line.
If your vent line is okay, then you can cap off or plug the return line that is next to your supply line. The reason I don't is that it is supposed to help with vapor lock to keep fuel circulating through the pump. The cooler fuel can then push past the hot fuel in the line going to the carb to keep your line cooler and keep the fuel from changing into a vapor.
It's theory, but the three line pumps seem to do better than the two line units.
