Funny Car Related meme's
maybe 10 years ago....now $3000
Sounds about right! This is verbatim from the description in this ad…”Frame is good, floors are good with little rust. The rear bumper is rotted out. Exhaust is good, aftermarket catalytic converter. Motor and trans both leak oil, bottom of engine oil pan is dented a little. Parking brake cables are free and work. Rear springs appear to be sagged. I did not check the front end, however there is not any severe alignment wear on the front tires. The gas tank is leaking a little from the middle seam, so it will leak above 1/2 tank. Vinyl top is split and will need to be replaced. The seats appear to be in very good shape, the front seats had covers on them, the darkness on the seat fabric is from the foam on the covers, it will clean right off. The passenger front seat does have an area that will need steam cleaned, where a drink can froze and leaked. Headliner needs replaced, the fabric was re-glued and it is wrinkled all over. In the trunk there are extra chrome rally wheels, a factory radio, an ash tray, and fiberglass inserts that I believe go behind the rear bumper. There is no power to the power windows, the driver's window motor is bad, I can get the passenger window to go up and down by jumpering power to the window switch. The battery that is in this starts the car, but I would not consider it a "good" battery. I drilled out the ignition switch and have been starting the car with a screwdriver. I did find a door key inside the car on the floor. The car does run and drive, I did run it down the road a few miles up to 45 mph. It runs well. This sat for I would guess 4 or 5 years at least. The tires are flat spotted. I would recommend trailering it if going any distance.”
