fuses (yes i used search)
jay_GM
Jan 31, 2010
87
does anyone have a diagram or something about the gbody regal and their fuses? my speedo light wont come on anymore and i think it may be a fuse (hopefully thats it) but every other connection works, so i needed a guide or something to know what im yanking out and many of these fuses dont have a number theyre smeared or erased and different colors than what im used to. thanks!
Speedo light? As in illumination? Have you checked the bulbs?
Grab a flashlight and a set of needle nose pliers bro. Get down into your fuse box and start yanking them out one by one. It should take you no more than 5 minutes to find the burnt fuse, if that's your problem.
the cluster lites have a single fuse, if one lite is out then like Doober posted it's probably the bulb
and for testing fuses this is alot quicker and simpler than taking out each fuse..
images
RegalBegal said:
I need the year. they run from 77-80, 81-84 and 85-87.
its 1984 Regal Limited
yeah then it might be the bulb i did yank out all the fuses and none were burned, on another note I cant seem to find out what the ratings are on each fuse theyre all blue with smeared numbers so im not sure if its like under powered or something, this is the first time since ive bought this car i tried it out in night settings.
jay_GM said:
Doober said:
woa, blue/aqua says 60, thats what they all look like, on another note how do i replace the bulb inside? do i need to remove the entire instrument panel/cluster?
You're looking in the wrong section. The blue "maxi" fuses are 60 but the ones in you're fuse box aren't "maxi's" they are just regular and are rated at 15 amps.
