this car has already had a swap so im just cleaning up the wiring. the only wires that were being used were the wire to the dist. and alt. there is a wire to the starter solenoid, havent tested it or looked at a diagram but im assuming it is the wire that engages the starter since it is on the smaller bolt to the solenoid. now on the solenoid where the batt cable connects to there is a connector that splits to wires. one runs to the fire wall and the other splits to the alternator(im assuming this for the output voltage from the alternator) then this same wire that splits runs to firewall. i assume these wires power the fuse box. now the wires did have fusible links. i dont know how to tell what size they are cuz i want to replace them with an inline fuse holder. anyone know what size fusible link was used off the starter to the fuse box?
