so ive decided to ditch the engine and most like put in an OD transmission so...here's the plan
ENGINE
get a SBC and put it in, nothing wild, just something around 250 HP to be used as a daily driver. as many stock parts as possible will be used so replacement parts can be had easily and cheaply. most likely a new 350 with 249hp, 304 ft lbs of torque and a GM serpentine belt "conversion" which makes finishing the engine and getting it running that much easier and faster.
CHASSIS DRIVETRAIN & SUSPENSION
transmission will probably be a 2004r. its a bolt in, driveshaft doesnt need cutting, only a crossmember change is needed and they can be had with a dual pattern so it will bolt up to a 350 no problem.
new gears and a differential. since im looking at new gears i'll go ahead and get a new diff so i can have better traction over a open diff that spins one wheel. 3.42 will probably be the gear, an auburn diff and probably new axles whiles its all apart.
for the most part the front suspension in done but i want bigger brakes so i might use bbody spindles and 12" 1LE rotors. not sure about the rear brakes, i may go with a aftermarket disc brake conversion kit. replace the KYB's for bilsteins to match the bilsteins in the rear. KYBs are ok but not as good as the bilsteins. they're worth the extra money.
some trailing arms for the back but im not sure which ones to use. maybe some better springs.
WHEELS AND TIRES
wheels will probably be a set of cragar soft 8's, probably a 16x8 wheel all around so i can rotate tires, its a daily driver after all. not sure what tires i'll use yet. its a daily driver so they cant be some high performance type tire, just one that provides good traction.
BODY
i MAY change out the nose for a 2+2 nose conversion. maybe. depending if i can find the right parts to fix the minor problem i have with the nose now. a broken bumper cover is a PITA to replace since they dont make any and finding one is impossible.
i might replace the chrome part of the bumper with a fiberglass unit to help lighten the car and i can paint it to match the car. im not a chrome person at all. same goes with the back bumper. i might use the aluminum bumper supports, not sure yet.
i am thinking of going with a flat bolt on fiberglass hood with a trans am shaker "scoop" molded on to it from VFN. since the misses likes the trans am, im going to put some trans am styling cues onto the car. also the side vents on the fenders though im not sure if i want to use the 79 style or the 80's style. i do want them to be functional, not just cosmetic. and a spoiler from a 80's firebird.
INTERIOR and weather stripping
nothing much will change, maybe some bucket seats and a console, maybe not. new carpet for sure and a headliner. recover the seats if i dont use buckets and that's about it.
weather stripping will be replaced, all of it. window sweeps/belts, whatever people call them, those are needed.
this is a rough draft, i'll be adding more as i go through it all and add stuff i havent put in yet.
ENGINE
WHEELS AND TIRES
BODY
