I just installed one in mine. Had it made with the GM flush mount ends, to use 4th gen F Body rear disc. Installation was easy.has anybody used quick performance complete rear ford end assemblys.good,bad.fit well?
Yes I bought one last year. It is very nice, fits like a glove. My only advice is to make sure the brake setup you pick is really one you want. It proves difficult to upgrade or change, I picked the QP disc option, after reading reviews, I decided to change. I had them keep the brake setup, saved up and got the Wilwood brake setup. No go, backspacing/clearance was an issue. I had to explain to the QP tech which was a breeze what I did. I had to send them in and were retooled for clearance. Not the best but no cost to me and now all is good.has anybody used quick performance complete rear ford end assemblys.good,bad.fit well?
i didnt see an option for f body brakesThis is with the F Body rear disc.
Billet GM Flush w/ seal surface (for use with 93-02 GM F body rear disc brakes only) |
this is all i see
Housing Center Piece |
Housing Upgrades | Drain & Fill Plugs w/ Jack Pad [+$55.00] Adjustable Lower Control Arm Brackets [+$30.00] 1/4" Heavy Walled Axle Tube [+$30.00] Back Brace Installed [+$169.00] | |
Wheel Bolt Pattern |
Wheel Stud Size |
Center Section Gear Ratio |
Center Section Traction Device |
Center Section Upgrade (450-650 HP) |
Brake Kit Options |
Brake Lines |
