G body REAREND housing bushings ????'s
8,202
17,609
Moog K6411 problem solver bushings, set of 4 that you can probably get anywhere. Not expensive. Much better than stock, but won't break your wallet. About 26 bucks or so for all 4 on rockauto. Of course, you already ordered the UMI's so never mind. Harder durometer than stock, but then you won't have the squeak problems that a lot of aftermarket polys have.
I'm supposed to have couple dozen or so of the NOS Camaro 1LE bushings somewhere according to my parts list that fit G-bodies. (They use the same LCAs as G-bodies.) GM p/n 10164152. They're hard as brickbats compared to stock, but look like the stock mushy bushings. I bought up a buttload of them when I still had my 2002 Camaro SS and SLP was clearing them out.
12,178
9,779
The Camaro 1LE bushings are what I used on my lower control arms. I've also heard that they're NLA from GM.
ssn696
Living in the Past
5,548
6,675
Permanent Temporary
I used a pair from Speedway. Non-servicable, but they will deal with the binding problem these cars have.
