Gasket help
jeremyandthemonte
731
150
hey guys I need some help so I bought these gasket and I know I have the little hole in the centre for what I think is an exhaust crossover or something but my question is can I use these gaskets they cover the hole and will I be okay with just the gasket covering it ?
I wouldn't use that gasket. It is clearly not intended for this type of cylinderheads. If there's really hot exhaust gas coming through that hole, the gasket will soon burn and get destroyed by the heat, leaving you with a lot of other troubles...
always use the propper gasket in a setup, even if it means waiting some time before you get a hold of the right ones!
