Head gasket help
purple78monte
13
2
I’m swapping heads on my 355 and was wondering what head gaskets would be best to go with and what bore size should I go with for those gaskets heads are just regular cast iron heads motor has been bored 30 over
Clone TIE Pilot
3,861
2,612
Galaxy far far away
Generally you want to use as thin of a head gasket you can get away with for proper quencn. Depends on how far in the hole your pistons are.
purple78monte
13
2
I believe 0.39 is the thinnest I could go if I remember right but what about for the bore size I was think 4.125?
bracketchev1221
1,415
1,654
Those are the base replacement head gaskets. yes they will work with steel heads. The issue is when you use aluminum heads with a stainless fire ring gasket and it can leave marks on the head surface. Almost any head gasket will work with a steel head.
Ernest
745
1,012
Texas
