GBOTM: July '15 Entries Thread
85Supreme
1,283
16
38
29
Hey guys, this month I want to see everyones project car what they're working on. Enter your ride if you have a project car that is currently undergoing some heavy work. It shouldn't be something that you are fixing up as you're driving it.
Thanks,
Mike
I'd like to throw my hat in the ring on this one...
"The Juggernaut" ProTouring 1980 Olds Cutlass
Currently undergoing long term body off build.
455 big block Olds 500hp
Borg Warner T56 6 speed
On air ride with RideTech, UMI, Hotchkis, Global West suspension components
Custom 3" side exit exhaust through the rear quarters
18x8 front and 18x10 rear Foose Nitrous Thrust wheels on Toyo Proxes
Wilwood 4 wheel disc brakes, 14" 6 piston slotted/cross drilled rotors front, 12" 4 piston rear
Narrowed Chevrolet 12 bolt Posi w/ Moser axels and 3:73 gears
Scratch built steel cowl hood, shaved door handles, F85 inspired rear firewall, and many more body modifications
Build thread: https://gbodyforum.com/threads/the-juggernaut-build-thread.55095/
Concept sketch:
Work in progress:
been a work in progress since i was 15. 350 crate engine, electric exhaust cutouts, air ride, custom fender flares, modern interior, shaved doors with poppers, shaved trim, phantom grill, foose wheels, and a ton of other work all done by me.
Well I'll throw in even though its nothin fancy. I'm workin on the restoration of my white 87 monte SS. Its my first car and I've managed to hold on to it this long, so I thought it was deserving. This is nothing fancy as far as custom build stuff though it will have a 98 LS1 with a T56 behind it. I reworked the f body hooker long tubes to work with the g platform and have gotten the frame mostly done with an SC & C stage two kit. Up front will be vette calipers on the blazer spindles and in the rear will be "LS1" rear brakes. All fluid lines will be plumbed with cunifer.
Like I said its more of a restoration, a slow one at that!
My newest project that is moving pretty slow is a stock 85' Regal with a V6 with a rod knock.
I am currently rebuilding a mild SBC with a 350C trans to go in there and will be making brackets to keep the AC on the passenger side.
The engine will eventually have a lot of polished aluminum and braided hose like my Monte (the parts are already here).
So far i added the rims I bought on Craigslist for $150 and the steering wheel I bought on Ebay
I will drive it how it looks right now for probably a year or so just replacing bumper fillers etc. and then later on convert to how I really want it to look.
Mine's a project!... Currently in paint jail.
1983 Olds Cutlass Cruiser.
Originally a 3.8 V6/TH-350 car.
Mods include...
1974 Chevy 350 V8, TH-350 trans
DynoMax headers, true dual exhaust with Flowmaster 40's
Sweet 15x7 & 15x8.5 U.S. Indy aluminum slots
Ralley gauge cluster
1983 Cutlass Calais Sport wheel and bucket seats
1978 header panel and front bumper
Aluminum hood
As found in a Texas junkyard...
Pre-disassembly...
In progress...
Should look similar to this when it's finished...
bump
locked
