I am going to buy an extra engine stand for my new big block build since I currently only have one 4 legged stand which is maybe 1000 lbs. capacity but since I have to swap parts between both big blocks I will need another.
At first I was thinking about getting a 2000 lb. folding stand but have also thought about a gear driven style to make my life easier for the new engine.
One of my concerns is mounting the engine to the geared stand since normally I remove the mount from the stand and bolt it the block and just put the stand on while the engine is still hanging on the picker.
I am used to turning over a fully loaded big block manually so I am wondering if it is worth the extra expense.
One I was looking at was Summits which appears to be made by Sunex:
http://www.summitracing.com/parts/sum-908300ga
![sum-908300ga_ml.jpg](https://cdn-0.gbodyforum.com/proxy.php?image=http%3A%2F%2Fstatic.summitracing.com%2Fglobal%2Fimages%2Fprod%2Fmediumlarge%2Fsum-908300ga_ml.jpg%3Frep%3DFalse&hash=0172edb89f5aad39ac855fb5fb684ee1)
