MONTE CARLO Gear Indicators
chuckfenn1
117
59
59
Has anyone repaired a gear indicator? Mine in my 82 Monte Carlo is stuck in the P mode
Look under the RH side of the column under the dash. There's usually a mark on the shifter bowl where a clip was, or the clip can still be there with just a piece of the cable attached.
Cross fingers that the clip just slipped off. Those wires get busted a lot, though. You'll have to disassemble the gage panel to get to the cable to replace it if needed.
82-85 Monte Carlo says it uses GM p/n 25017051 for the cable, according to parts information available.
It appears they're available aftermarket if you need one.
SHIFT INDICATOR CABLES 78-87 - El Camino Manufacturing
