Has anybody seen one of these, it's a GN rear end with disc brakes? I just picked it up and wanted to know if anybody has seen one or know about the drum to disc swap.
You are absolutely correct, it is a conversion and there is no hookup for the emergency cable so you are probably correct twice that they are the same calipers as the front ones.jrm81bu said:I don't see any provision for an emegency brake(maybe I missed it), so I would have to say its a conversion. I know there was one out there that used the same calipers that our cars use on the front, kinda looks like that.
Yes the hoses will have to be changed anyways as they are cracked so i will change the setup on them somehow.85olds4spd said:The one thing i do not like is the brake hose is higher than the bleeder. I would think it would trap air. I would modify that if it was mine.
