I got news. It's a 305 with stock heads, Q-jet, but has headers. I'm guessing it's a completely stock LG4, which I figured it would be.
I wanted to see if it would at least start before anything else. So I hooked up a fresh battery and.. click! Nothing, no movement.
I know the battery is good, so I took a breaker bar and tried rotating it by hand, but again nothing. After that fail I removed all the spark plugs and spayed some wd40 in the cylinders to try and free up the pistons. Water poured out of 6 and 8.
So I took the bore scope and looked in the cylinders to find #2 clean but worn, #4 with water deposits, and #6 and 8 with at least a half inch of water inside.
Thoughts?
I'm thinking turbo 3.8! JK if it was mine I would.
