I was wondering if anyone knows of a place that sells a radio install kit for a 1980 Grand Prix. I took the cd player out of my old daily driver and want to put it in the 1980 Grand Prix dash I put in my car but can't find a kit to install it. I know the wiring I just need one of those mount/install kits.
Well assuming that its a U Style Radio in there now with the Knob on the left and one knob on the right with the push button presets you wont find a kit to put a Modern CD Player in there... You will have to do what I did and cut the Trim Pannel with a dremel and then get in there and dremel out the steel that the old knobs went thru... Once that is done you will need to get a 1/4 or 1/2 in trim plate (Thin piece of black plastic that goes over the hole you just cut either 1/4 or 1/2 depending on how straight your cut is) So then get your mounting bracket for the CD Player and put that thru the trim piece and then put that on to your trim for your car and bend the tabs out and your done.. I did it to my car and have never had a problem the only problem i have ever had was I broke my trim by making the screws to tight DAMN good luck let me know how it turns out....
What type of radio are you puttin in it? Is it aftermarket or just from a newer vehicle? If its aftermarket you can find an install kit at walmart or meijers or anywhere that sells car audio. I got mine for the monte at meijers and it works fine.
My old 80 GP had the factory plate with the big hole already. So all I did was buy one of those install kits from Canadian Tire and everything bolted up. They also make wiring kits so you don't have to hack your factory harness. I don't know if you have a Canadian Tire where you live, but most autoparts stores have them. Car audio shops usually have them too.
I cut the factory knob radio plate to fit the aftermarket radio sleeve. I tried an aftermarket kit that was supposed to fit my car, but it didn't. If you don't have the factory radio plate, see if you can get one out of a junkyard.
Well here is some pics. The radio I want to install is an after-market one. The first one is of the radio that came with the dash when I got it out of the junkyard. As you can see it has 4 hole for mounting it. Don't know if this is the U style radio? Anyways the second pic is of the one I want to put in the dash. It has a black plastic mount on it but I bent the tabs so it slides right off. It only has 2 mounting holes on it and they are not even close. Also the third pic shows how much wider the factory one is. I really do not want to cut up the factory faceplate as the radio is in perfect condition and I might want to reinstall it someday in the future. And a lot of junkyards around here don't have older cars in them. So I am hoping that there is a kit.
The one in the pic isn't a kit I bought, It's the kit that was used in my daily driver (92 chrysler) which I took the radio out of. I was just wondering if anyone knew of a kit for it and was just comparing the size of the cd player I want to put in there to the original one. I looked at some kits at best buy and walmart but none of them said they would fit.
