your input was the spot on for the negative burn out to the body. The main negative cable switched to the alternator bracket needed some paint removed for a solid contact and that solved the burn out appreciate your experience and shared info.Been here, done this. Check your battery to engine ground cable connection. I suspect your main ground cable is not connected properly at the engine. When this happens, the small ground wire from the battery to body tries to take the load at engine startup but can't handle. So it overheats and melts.
Remember, a tight connection is not always a good connection. Clean both the battery ground wire as well as the where it mounts.
Your most welcomeyour input was the spot on for the negative burn out to the body. The main negative cable switched to the alternator bracket needed some paint removed for a solid contact and that solved the burn out appreciate your experience and shared info.
