I suspect the harmonic balancer on my Chevy 305 maybe going bad or has slipped. I noticed the outer ring is almost touching the timing cover, almost a paper thin gap. Looking under the car, I can see the inner hub and rubber ring stick out forward from the outer ring. Heard that when balancers slip, the outer ring can migrate inboard towards the timing cover. The rubber ring does not appear to be sheered or separated though it does have a couple of cracks and looks worn and beat up. As far as I know it is the original balancer to the engine which has 100k on it.
