So, as related elsewhere, I did finally drop the LS6 manifold into position on my LS2 mill. It went in with a set of new port gaskets as, when I lifted the old ones, there was oil under them for which I elected to use alcohol as the cleaning solution of choice. i did have to very gently and circumspectly take a machinists file to the casting flash along one side of the galley cover near the driver's side rear to obtain a little wiggle room to get the manifold to sit down square so that the capscrews would align. They still need to be torqued which will require a 1/4" drive inch/pound torque wrench to complete.
However, now I am looking at a possible injector wiring harness plug anomaly. The pins on the injectors in the old manifold seem to be centered in their sockets. The ones in the -6 manifold however seem to be offset ever so slightly towards the manifold body. Is this an optical illusion or do I need to pop out the old injectors from the old manifold and re use them in the newer one?
