Yes, definately pull number one plug, roll it over with your finger over the hole until you feel compression. At that point you can stick something rigid into the spark plug hole, like a screwdriver, or the likes. Roll it on over BY HAND!! until the piston stops pushing the screwdriver out of the hole. When you get to TDC, kinda roll it back and forth, with the screwdriver being your indicator, until you feel you are EXACTLY TDC. Check your timing marks. You may have a slipped elastomer ring or the wrong timing marks. If so, make new ones now. Pull your dizzy cap, verify your rotor location. Wire it accordingly. Clockwise, 1-8-4-3-6-5-7-2, UNLESS you have a 7-4 swap cam, which we run in our race motors. Then it's 1-8-7-3-6-5-4-2. Better harmonics. Did YOU build the motor? Did you have compression while rotating the engine over on the engine stand? You may have the cam 180 out too. Start your diagnostics simply. I had my *ss HANDED to me on a super trick Camaro the other day. I would check for spark, by pulling the coil wire out of the cap and it would run. Plug it in and it would die. Turned out the carbon tip was gone from the cap. Don't ask my why it would run with the wire pulled and held 3/8" away from the cap, but it did. We threw on a replacement cap and it runs like a champ. Also , if it's a fresh motor, with a flat tappet cam, you better figure this one out quick, or you will grind your new cam into the dirt. Roller cam? Your only issue will be wearing your starter out! Cheeres and let us know- Matt
