Put in some new headers, the transmission lines now run along side the collector and block the starter from being installed. A search resulted in reading about using rubber hose for a short distance to connect the lines to an external cooler. Will rubber (even with ss braiding) be sufficient for replacing entire transmission line to run along the passenger frame rail? Or is it better to custom bend a metal hose?
If using metal is better, how much skill and patience is needed. Will I need any special tools besides an end flare tool?
