Long story short I didnt see the car until he brought it to me to fix a trans and oil pan leak. Here is what he was told. The car which is a 85 regal is suppost to have and be the following. Now the guy stated he built and did it all himself.
Suppost to be a 11.40 car
40o sbc 40 over with trw piston
Eagle crank
Eagle rods
RHS alluminum heads 220cc
Comp cams 1.6 roller rockers
630 lift roller cam
Air gap intake
8.5 373 posi
Th350 with stall
6 point cage
Here is what he got
400sbc 30 over trw piston
Stock 400 gm crank
Stock rods
Junk procomp 160cc heads
Cam dynamics 1.5 roller rockers
450 lift flat tappit cam estimated by dial indicator.
It does have the airgap
7.5 373 posi rear
Trans was a 350
The cage is a nicely done 6 point though
Now he has the guy craigslist add and a paper with all the parts that he said was in the motor written by him. Does my buddy have any ground to stand on or is he sol. Everything the guy said is turning out to be a lie. I only know what pistons are because i used a cylinder scope. Same goes for cam looked pushrod hole
Eagle crank
Eagle rods
630 lift roller cam
Air gap intake
8.5 373 posi
Th350 with stall
6 point cage
Here is what he got
Stock 400 gm crank
Stock rods
7.5 373 posi rear
Trans was a 350
