Beautiful! I'm about to do the same install myself - Lt1/4L60E out of a
B-body into an 86 Elco and have a ton of questions.
Did you have chassis clearance issues with the A/C compressor and how did you resolve them?
I needed to add space at the front to clear the compressor clutch. Used a torch to heat the frame some and beat it in with a hammer.
At the rear of the compressor, I cut a small notch to add clearance.
What radiator did you use?
At first I used a new stock radiator. I had cooling issues. I tried a couple of fan combos but it didn't solve the issues.
Bought a new Champion 3-row and their dual fan shroud. But I bought the fans separately and got a pair of Spal's.
Cools very well with that combo. I'm using only the radiator cooler for the transmission but do have both an oil cooler and power steering cooler mounted horizontally on to the bottom of the radiator core.
Did you get a PCM tune? From where?
Yes. Fuel Injection Specialties in San Antonio made my wiring harness and altered my PCM. Turned off the VATS, eliminated EGR and set the rear ratio to 3.42.
Do I understand you used a Walbro external fuel pump up to now?
I've had 3 fuel in-line fuel pumps on this since the engine install. First 2 died and 3rd was a Walbro which I believe was a lot better of a pump.
Just changing to an in-tank pump now. Using a Walbro for that too.
Did you use the OE fuel lines?
Only line that is original is the one that goes to the carbon cannister. I've got the purge line inserted into the air filter box I'm using. It seems to work but not very sophisticated.
I did not use the stock lines after installing the engine 20 years ago. Used rubber all the way. Knew it wasn't great to do that though. I was more lazy back then.
I just ran new hard line up the frame for supply and return. Both 3/8" and all AN fittings. Converts to short lengths of rubber at the engine and tank.
I've collected a bunch of parts anticipating putting the drivetrain in my '48 Chevy street rod project that I've finally burned out on in favor of the Elco. I've got a '95 Z28 gas tank with pump - any idea whether that might work? I'll get some pix of it up some day soon.
Don't know but I doubt it. The tank for the Elky has to be a pretty specific shape.
(I've also got an 8.5" rear end I spent $1400 on to get 3.23 gears and an Eaton Posi in; only trouble is it's in a leaf spring axle and would probably cost more to adapt than it'd be worth.)
I guess a better question is do you have an original build thread anywhere (was '98 before Al Gore invented the internet?)?
Ha! I do not. I didn't take photos back then like I do now either. I kept a note book that is pretty organized though.
Any engine/transmission mods? I had a ZZ3/4 cam modded and installed it with the recommended valve springs, installed a 2800 RPM Yank torque converter and a TransGo shift kit so I was desperate to use the engine and transmission and when the Elco came up for sale I had to have it.
No, all stock inside. The '96 engine and transmission were new when I got them. (Only 26K mi on it at the present.) I had to make a modification to the valve body of the transmission because I used a '94 PCM. The lockup works differently and it wouldn't ever lock up without the mod.
I'm sure I'm not out of questions.
Cheers - Gary
Edit - New question - After all the hassle of the new headers, would you go a different way if you were starting over replacing the cast iron 305 exhaust manifolds? If I wanted an easier way and weren't as concerned about performance, would you recommend a less troubling solution? Right now I've got street rod block hugger style headers and have no clue whether they'll give me any clearance problems - they fit fine in a '48 Chevy engine compartment.
